跳转到主内容
Vaio laptop replacement battery not detected.
I replaced a failed battery in my Vaio laptop model SVP112A1CL. Windows 10 64 bit OS. The battery was initially seen but is now not seen by the OS. The only message is "battery is not detected". Any help would be appreciated.
Also, (I'm posting this as a separate question as well) The SVP112A1CL is not in the Sony list of laptop models. I don't know why. Does anyone know the equivalent model I should use for Firmware, drivers etc. downloads?
Thanks for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@sumus , Jerry, found this info. at a Sony sight. Sony has two codes that look the same-ish, the model number and the chassis number. The SVP112A1CL is the chassis number which is why it doesn't appear on the support website. Your model number can be found a number of ways. You found it in Vaio Care and you can also find it by booting the computer from the Assist button as well as somewhere on the computer itself (the model number likes to hide).
Sony does state replacement batteries must be OEM battery, but as I searched through some forums there were a lot of Vaio lap tops having this problem, find some informative links below, I think what it comes down to is actually Sony has to release new update/driver. Sony support is the last link, they may have the fix/update. Check the attached links,instruction and guides, Good luck.
https://community.sony.com/t5/VAIO-Hardw...
http://answers.microsoft.com/en-us/windo...
https://www.youtube.com/watch?v=_hMccvsW...
https://esupport.sony.com/US/p/os10upgra...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jerry Wise 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 15,298
