跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
SSD write speed low
Hi guys,
I just installed a new Crucial 750gb SSD in place of my old HDD. I also installed 16gb ram.
I'm running Mac OS Sierra
I ran black magic disk speed test and for some reason my write speed is only 250 mb/s while my read speed is 450ish.
Any advice to improve my write speed? everyone who I've seen make this change on this Mac Pro model (9,2) seems to have higher speeds.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Replace the HD/IR cable. Take it to an Apple Authorized Service Provider (they have a financial incentive to help you, Apple pays them for the repair) and they may do this for free on this model. This is (as far as I know) an unannounced replacement program on this model.
这个答案有帮助吗?
得分 2
添加一条评论
Hm, try resetting the PRAM and see what happens. Also, check if the RAM memory works ok. Also, please check that the SATA cable isn't scratched somewhere or it wasn't put the right way in the bracket.
Good luck!
这个答案有帮助吗?
得分 1
3条评论:
I reset the PRAM and no change.
I also ran apple hardware tests (from shutdown "options-D) with no problems found.
完成的
It's not that I'm finding the system slow or anything. I was just expecting a higher write speed.
完成的
I personally dont like Crucial, Kingston or OCZ suits better to me... :(
Bad luck.
完成的
添加一条评论
添加你的答案
Nicholas Presgrave 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,487
