跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
Battery connector socket broken
I was replacing a battery and when I was closing the phone, I realised I left a piece out. I had to disconnect the battery but the socket came off. I think it isn't so bad as the phone powers on if I place the socket correctly and put some pressure on it, but I'm going to need help putting it back in. I have a lot of experience soldering but not with parts this small.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here is an example of one of the many guides to perform this repair. Watch a few and see some different techniques. You may need some specialized equipment depending on the technique you choose. Perhaps some low melt solder.
https://youtu.be/zprpD5gYeQI
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samuel Rey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 35
