跳转到主内容
加入维修社区 - 创建账户
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Is my machine motion sensitive?
I picked my iMac up a few cm above the desk it sits upon and tilted it a few degrees in all three dimensions and it shut itself off. I am certain that the power cord did not become temporarily disconnected. Other than the power cord the only other peripheral connected was the wired apple keyboard with the wired apple attached. No connections are/were loose. My computer has never sustained any physical damage. It has not shut itself off since, but I have not tried to reproduce the situation since it results in a hard power off. Is this model of the iMac designed to react this way during this situation?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
You mean
Like this?
Yes there are SMS (sudden motion sensors) on Intel iMacs - but moving any running computer is still an excellent way to destroy a HD.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 2
添加一条评论
You iMac should not be motion sensitive. You may have moved some component when moving it. If you do it again I would shut down first.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
xanthus702 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 893
