跳转到主内容
加入维修社区 - 创建账户
Acer Aspire 5334 基于 Windows 7(64 位)系统,拥有 3 GB 内存,搭载 Intel Celeron 900 (2.2 GHz) 处理器,于 2008 年 1 月发布。
computer won't boot, hard drive error
can't seem to get my computer to boot up to windows logo, I keep getting this hard drive read error.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Did The Computer Recently Get Dropped ?
完成的
yes my sister recently dropped.
完成的
添加一条评论
2个答案
已选择的解决方案
Ok. Since the Laptop Was Dropped. We Need To Check And See If The Hard Drive Was Knocked Loose From Its Tray. Whats The Exact Model Number Of Your Laptop. We Have Acer Aspire 5334 There Should Be Four Other Numbers. Most Likely Your Hard Drive Was Knocked Loose And The Laptop Cant Find It.
On The Bottom Of The Laptop There Is This Cover. Big And Long. Take A Screwdriver And Remove That Cover. Take A Look Inside And See If The Hard Drive Is Knocked Loose.
If It Did. Just Slide The Hard Drive Back Into The Connector.
Let me Know What Happens :)
这个答案有帮助吗?
得分 3
2条评论:
I Hope This Fixes It. Because Other Wise The Hard Drive Might Have Been Damaged. Does The Hard Drive Make Any Noises Upon Turning On The Laptop. Clicking, Ticking etc
完成的
thank you so much, i followed exactly what you did, and everything works just fine now.
完成的
添加一条评论
what is the error message that hard drive is giving? Did you try to reinstall the Operating System? If you did, did you receive any error messages? If so what were they?
这个答案有帮助吗?
得分 0
1条评论:
I reinstalled operating system and everything works fine now. thank you
完成的
添加一条评论
添加你的答案
gilson teixeira 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 4,413
