跳转到主内容
加入维修社区 - 创建账户
Wi-Fi版的iPad Mini 2指南。2013年10月22号发布同年11月12号上市。iPad Mini 2就是配备了Retina显示屏的iPad Mini,在更小尺寸的的7.9寸屏幕上拥有和iPad Air相同的像素。
Why I have white vertical lines on the screen?
I'm using my ipad then white lines come out of nowhere. I have an image in this link (apple disscusion). Please help
https://discussions.apple.com/servlet/Ji...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
This just happen to mine too.
I can get it to go away by locking the screen and unlocking, but it will fritz back again.
Mine, unlike yours, seem to keep in a horizontal direction. If I rotate the iPad, the lines rotate as well.
The reboot Apple logo is washed out.
I am really quite unhappy by this.
I wish I had an answer for you. But I don't yet.
I've factory reset the iPad, updated the firmware to 10.1.1, and restored.
It is still doing this.
What happened was that I connected my iPad to the Apple Lightening to HDMI connector with a suspect HDMI cable. I had used my regular HDMI cable the night before and it worked fine, but I found this longer one I had from my parents' place and tried to use it. I think maybe the cord did something to my iPad… maybe.
That's all I got for you. @jetaudiomedia, I hope you can figure this out too.
I "might" still have some extended warranty from my Visa on it, but we are talking mere days left.
完成的
Could you please post the link to your Apple Discussion group thread as well in case someone posts a possible answer/solution there? thx.
完成的
Hi, as I posted on the Apple Discussion page, did you ever come to any resolution for this problem? What ended up being done?
完成的
Did you find a solution for this? I have this too !
完成的
显示更多的1条评论
添加一条评论
6个答案
最有帮助的答案
Hi guys, I have had 36 clients approach me with the same problem. I saw no drop damage. Some are even so careful that I believe their iPad mini 2 and 3 never even witnessed a drop let alone a scratch. Bottom line is, I had to replace all their screen, the one underneath the touch glass. SO far none of the clients returned to me for complaints. I believe this is a hardware issue, a design flaw from Apple’s part. I also believe mini’s are plague’d with this white line problem.
这个答案有帮助吗?
得分 1
添加一条评论
I had this happen to my gen1 ipad many years ago. I took a chance and bought a no longer charging ipad gen1 that appeared to have a good screen on ebay. When I replaced the display the issue was fully resolved. I believe it is just the screen going bad sadly.
这个答案有帮助吗?
得分 0
添加一条评论
why is this happenening help me
这个答案有帮助吗?
得分 0
添加一条评论
I also have this on my iPad Mini 2. I have had this iPad for two year now and it had just begun doing this last month. I think I should just get a new one.
这个答案有帮助吗?
得分 0
添加一条评论
I have found that putting the brightness on maximum reduces the chances of this happening. Sometimes I need to turn the screen off and on a few times.
这个答案有帮助吗?
得分 0
添加一条评论
I got rid of mine by having the “battery replaced” by Apple at the Apple Store. In this “repair” the whole device gets replaced with a new device. It solved a bunch of my problems, including a stuck Home button.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jetaudiomedia 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 72
总计 10,444
