跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
How to separate the LCD Screen display from the Touch panel?
My iPod Touch's screen doesn't work, only displays white color. All the others work, the touch screen, even is sincronize.
I read the teardown part, when you describes that the front glass and LCD are permanently fused together, increasing the cost of repairing broken front glass. But I found on eBay an LCD display, whitout the touch part. It's possible to replace only the LCD display? It does not matter to me to destroy the LCD.
Here's the link of the display:
http://cgi.ebay.com/OEM-LCD-Screen-displ...
Thanks! And sorry about my bad english. I'm from Mexico.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Your English is perfectly readable, btw. :)
完成的
添加一条评论
3个答案
已选择的解决方案
I don't think it's possible; at least, I looked at an old bad (cracked) iPhone 4 screen, and it really really was impossible to separate them, even if you destroy the LCD.
Is it ethical to sell parts that can't actually be used? :/
这个答案有帮助吗?
得分 1
添加一条评论
To OP:
they can not be separated.
Stupid eBay sellers sell these because people looking to do the replacement on the cheap will buy useless parts.
Plain and simple: Buy the assembled one. Just did a replacement a few minutes ago, easy and smooth.
这个答案有帮助吗?
得分 1
1条评论:
I agree - Apple glues them together with a really strong adhesive. Industial design as it shouldn't be.
完成的
添加一条评论
Is it possible to replace the original lcd/digitizer @#$ with two separate parts? A lcd panel and digitizer or do they have to be one peice, as it were?
这个答案有帮助吗?
得分 0
1条评论:
Do a search about this on ifixit. Personally I advise against it, some say it can, most say "No Way" I suggest to replace it as a unit.
完成的
添加一条评论
添加你的答案
shamefftl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,220
