跳转到主内容
The second generation (KK) Jeep Liberty, a compact 4-door SUV that restored the classic sharp lines of the original Jeep styling.
19 个问题 查看全部
heater blowing cold air
2008 Jeep Liberty
ac working good. heater blowing cold air. coolant level is good. temperature gauge in good level. floorboard not wet like other autos I've had that had bad heater core.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
最有帮助的答案
I would take a look at the actuator. Here's a very good answer on this with diagram on it:
http://www.justanswer.com/jeep/7fdvs-lib...
这个答案有帮助吗?
得分 4
添加一条评论
Take the two hoses near the fire wall to the heater core off and flush it out, make sure to flush out in reverse, so as not to push obstruction further into the heater core.
Take a water hose and flush it out till clear of obstruction
这个答案有帮助吗?
得分 1
添加一条评论
Most likely be the resistor behind the glovebox. Very common issue
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kathy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 35,195
