跳转到主内容
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
lack of power in transmission drive and mower deck
The mower blades slow down considerably when I get to some thicker grass. It never used to do that. Also the mower does not have enough power to pull itself up a hill.This problem just started to happen recently, the mower was operating perfect most of the summer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Don, If mower gets used a lot, may just be belts slipping from wear. If all belts look good, there are few things that can cause your mower to loose power, bad fuel/filter/Air filter, carb. out of adjustment, failing coil running on one cylinder, valve adjustment required, engine worn/low compression, faulty plug, fuel pump starting to fail, etc. Two of the most common are fuel tank cap vent starting to plug(loosen cap to see if engine improves), the other common issue is a dirty carburetor, which will have to be removed cleaned/rebuilt . Good luck.
这个答案有帮助吗?
得分 4
1条评论:
I had the same problem... I added some LUCAS deep clean fuel line cleaner and it improved greatly
完成的
添加一条评论
Check to see if the transmission drive belt is worn or there is enough tension from the idler pulley spring.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
donbrown24 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 4,810
