跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
244 个问题 查看全部
Is the ssd upgradeable on MacBook Pro 15" with Touch Bar
I purchased a 256 GB model, and wish to upgrade SSD.
Is that possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
15条评论
No it is not. The SSD is soldered to the motherboard.
完成的
No, the SSD is NOT soldered to the motherboard.
完成的
Alex, the SSD on the MacBook Pro with touch bar is soldered. You can't replace it.
完成的
But, could someone un-solder it and replace it that way? Are the parts out there? Just curious...
完成的
显示更多的10条评论
添加一条评论
2个答案
已选择的解决方案
The SSD is soldered to the motherboard. You will have to return it and get the one you wish or do some very risky de-soldering which has a 1% success rate.
这个答案有帮助吗?
得分 4
3条评论:
IMHO it is not soldered. I saw some openbox videos on 13' model. Are you sure?
完成的
Yes! The Touch Bar version systems both have soldered RAM & SSD. Only the new function key model has a removable SSD and its a different interface than what Apple had been using.
完成的
Gotta return it!!
完成的
添加一条评论
Get buyers remorse. Take it back and get the model you need or you may be stuck with it for a couple of years until OWC comes up with a replacement. See their blog here:
http://blog.macsales.com/38440-ssd-in-la...
这个答案有帮助吗?
得分 1
1条评论:
@mayer - Sorry the new touch version MacBooks Pro's don't have a removable SSD! Here's the poop: 15-Inch MacBook Pro With Touch Bar Has Non-Removable SSD The 13" is no different.
The new function key version 15" MacBook Pro Does have a replaceable SSD! But, its still a different interface than the older SSD's Apple has been using. Which is what your link is about.
完成的
添加一条评论
添加你的答案
Yao Meng 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 35
过去 30 天: 143
总计 63,520
