跳转到主内容
MacBook Pro带有15寸屏幕的型号
8262 个问题 查看全部
Not booting up properly?
I had liquid water damage on my MBP 15" unibody late 2008. I took it to Apple and as we all know its not covered. I ordered the correct motherboard and replaced it. Now when I go to turn it on it doesn't regularly turn on meaning I have to press the power button 30 times to get it to turn on once. I have reset PRAM and SRAM holding power button without battery and all the normal trouble shooting. When it finally does turn on the fans are on super high and the hard drive turns on but nothing else, nothing on the screen turns on. I don't have an external connector to check if it shows anything in an external display but I am going to check it out now and will update with what happens. It also does not charge the battery anymore. Any ideas would be great and helpful. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
don't try to turn it on anymore,
please open it and clean up the stain, and hope there is no blowed up IC/SMT Capacitor or inductor(this one is blew up since you can't charge the battery anymore).
and hole the LCD cable didn't short out, otherwise you really need a new logicboard and also new LED screen, and also new LVDS cable.
or otherwise clean it up until there is no other trace of liquid and ask for flat rate repair, that will cost you $300.
other than that, you only can use the SATA super drive, the shell and the hardrive, battery, and also the glossy Glass with MacBook Pro logo on it.
这个答案有帮助吗?
得分 2
添加一条评论
sounds
like more than just the logic board you bought was damaged... DC in and/or battery connector, keyboard/topcase damage.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,019
