跳转到主内容
Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832 个问题 查看全部
Why doesn't my iBook G4 recognize my Airport extreme card?
I have three Apple products with the same Airport Extreme cards installed in them.
The machines are a 1.5 GHz Mac Mini G4, a 1.67 GHz PowerBook G4, and a 1.33GHz iBook g4.
The Airport Cards are all as follows:
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x14E4, 0x4318)
Wireless Card Locale: USA
Wireless Card Firmware Version: Broadcom BCM43xx 1.0 (4.170.25.8)
Current Wireless Network: wireless
Wireless Channel: 6
All computers easily access a Netgear router except the iBook.
It does not recognize the Airport card that is installed.
Has anyone encountered this problem, and is there a solution?
Incidentally, all computers connect via channel 11 except the iBook which indicates channel 6 as shown above.
Thanks in advance,
Craig
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Look under the Apple in the upper left hand corner to "About this mac". Hit the more info button. Go to Network -> Airport and see if your machine sees the card. If not switch it with a known good one. Are you sure all three machines use the same card? What's the part number? Is it this card: [关联产品丢失或禁用: IF183-054]
这个答案有帮助吗?
得分 3
1条评论:
agreed +
完成的
添加一条评论
添加你的答案
Craig Pemberton 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 2,137
