跳转到主内容
苹果推出的面向个人消费者以及教育市场的笔记本电脑产品线。 iBook 系列包括 iBook G3 Clamshell,G3 12寸,G3 14寸,G4 12寸,以及G4 14寸。
Why doesn't my iBook G4 recognize my Airport extreme card?
I have three Apple products with the same Airport Extreme cards installed in them.
The machines are a 1.5 GHz Mac Mini G4, a 1.67 GHz PowerBook G4, and a 1.33GHz iBook g4.
The Airport Cards are all as follows:
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x14E4, 0x4318)
Wireless Card Locale: USA
Wireless Card Firmware Version: Broadcom BCM43xx 1.0 (4.170.25.8)
Current Wireless Network: wireless
Wireless Channel: 6
All computers easily access a Netgear router except the iBook.
It does not recognize the Airport card that is installed.
Has anyone encountered this problem, and is there a solution?
Incidentally, all computers connect via channel 11 except the iBook which indicates channel 6 as shown above.
Thanks in advance,
Craig
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Look under the Apple in the upper left hand corner to "About this mac". Hit the more info button. Go to Network -> Airport and see if your machine sees the card. If not switch it with a known good one. Are you sure all three machines use the same card? What's the part number? Is it this card: [关联产品丢失或禁用: IF183-054]
这个答案有帮助吗?
得分 3
1条评论:
agreed +
完成的
添加一条评论
添加你的答案
Craig Pemberton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,173
