跳转到主内容
A series of Gigabit NAS desktop drives of 1TB, 2TB, and 3TB varieties, made by WD in 2010.
9 个问题 查看全部
My western digital not appear in file manager
Western Digital my book was healthy until I connected it to the PlayStation 4 After , the device turns on the lights But not appear in the Windows file manager and disk management (in manage) but in "Device Manager" appears and i saw the icon for safley remove in taskbar . I was Tested with another cable, as well as with another system but it dosnt work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi, Can you 'see' it when you connect it back onto the PS4?
完成的
添加一条评论
1个答案
Did you look for it in your network Bottom section of File Manger - Labelled Network. My Network
Drive only shows up in the network since mine only connects to a network and has no USB connector. When you connected it to the PlayStation 4 did it in any way format or configure the drive to work with the PS4. If it did then it might of - formatted that Drive and now it will only work with the PS4. I would go to the WD Website to see if there is any Recovery software for your WD Live Book.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mohamadhajari 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 517
