跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touch IC or connector or both?
Got a 6 plus that is like this, does it need new touch ic or connector?
touch is bad so that needs doing and grey bars at top
the screen is fine, i just want to make sure the phone will display fine if touch IC is fixed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you're getting grey bars at the top 100% touch ic guaranteed. I also noticed your top right backlight is dim. If it's still this way after swapping the touch ic you need to replace part of the backlight circuit as well.
这个答案有帮助吗?
得分 1
3条评论:
that's what im talking about
完成的
You know on the top right that is usually either LCD connector on logic board or LCD ribbon cable needs to be pushed in more.
完成的
it can happen in either corner i have it on a 6 but not sure if it is, it only happened on the 6 because i test screens constantly so it got damaged. the connector looks fine to me
完成的
添加一条评论
添加你的答案
David F 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 128
