Horn 'button' does not work
How do I replace/fix the steering wheel activator system for the horn?
@leojik , Before pulling the steering wheel because your horn does not work, Check all fuses and horn relay and the horn itself. May be bad/corroded ground at the horn. Links below show horn fuse/relay locations, horn location and removal, steering wheel removal to access horns wiring/plug. Check the attached links,instruction and guides, Good luck.
http://troubleshootmyvehicle.com/honda/1...
这个答案有帮助吗?
I have put a live feed to the horn and it works but no live feed at the steering wheel and the srs air bag light is on
这个答案有帮助吗?
Through research for my own car, it appears that your issue is to do with something called the "coil spring". It's a device that allows the wires for the airbag, horn and other wheel controls to turn with the wheel without being damaged. Here's a YouTube video for you to take a look at: https://www.youtube.com/watch?v=3vFkSuoz...
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 55
总计 13,252
