跳转到主内容
加入维修社区 - 创建账户
How to fix the seventh generation of Honda's compact car.
Horn 'button' does not work
How do I replace/fix the steering wheel activator system for the horn?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@leojik , Before pulling the steering wheel because your horn does not work, Check all fuses and horn relay and the horn itself. May be bad/corroded ground at the horn. Links below show horn fuse/relay locations, horn location and removal, steering wheel removal to access horns wiring/plug. Check the attached links,instruction and guides, Good luck.
http://troubleshootmyvehicle.com/honda/1...
https://www.youtube.com/watch?v=0ra0E0ph...
https://www.youtube.com/watch?v=d0GHgOCh...
这个答案有帮助吗?
得分 6
添加一条评论
I have put a live feed to the horn and it works but no live feed at the steering wheel and the srs air bag light is on
这个答案有帮助吗?
得分 1
1条评论:
Through research for my own car, it appears that your issue is to do with something called the "coil spring". It's a device that allows the wires for the airbag, horn and other wheel controls to turn with the wheel without being damaged. Here's a YouTube video for you to take a look at: https://www.youtube.com/watch?v=3vFkSuoz...
完成的
添加一条评论
添加你的答案
Leo Klump 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 27
总计 13,871
