跳转到主内容
Are later model hard drives compatible with this model?
Apple Time Capsule Model A1254
The hard drive on my Time Capsule has stopped working. I was able to backup the data but now I need to replace the broken one. Will the hard drives from other models be compatible with the first generation? If not is there a third party hard drive that will?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
This guide should help even if is for a newer model: Apple Time Capsule Model A1302 Hard Drive Replacement
这个答案有帮助吗?
得分 5
添加一条评论
最有帮助的答案
Any hard drive with a working SATA port can connect and work as a storage device in your time capsule provided it is standard size or smaller. Replacing the drive is extremely easy and step by step instructions can be found in a future repair guide.
这个答案有帮助吗?
得分 7
2条评论:
What about formatting the new drive?
完成的
The drive is able to be formatted via the time capsule software interface on your computer. All the settings on time capsule can be edited as long as you're connected to the device through a ethernet cable.
完成的
添加一条评论
此回答最初是针对另一个问题
As an alternative to using a Time Capsule, investigate using a Raspberry Pi and a USB HDD. Check this out: https://www.youtube.com/watch?v=yJs8f0sp.... It will operate as a Time Capsule with Apple’s Time Machine backup program.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keaton Frahmann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 165
