跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20020 个问题 查看全部
If part of screen is displaying correctly, GPU should be fine?
I have fixed up a few MBP's (usually broken screens), and have a question.
If a MBP has a wonky screen in which part of the screen image is garbled and part is completely fine (i.e. you can see the OSX desktop), can you conclude with any certainty that the issue is the screen (or perhaps cable) and not the GPU/logic board?
In my experience when there is a GPU issue, the entire screen typically does not display correctly.
I understand the best way to confirm is to connect to an external display, but don't have this capability right now.
Thanks, Steve
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Thanks guys for the responses- it's a machine I am considering buying on Craigslist. Sorry to mention the model- it is the 2.2/2.4 15" model (mid-2007), so it does have the Nvidia 8600.
I will try to arrange to test the computer with an external monitor, I guess it is hard to say for sure otherwise. Basically, half the screen is fine, the bottom half has distorted banding pattern. I've seen this type of artifact before on bad/broken LCD's, so was just wondering if anyone else had experience with this pattern. Thanks, Steve
完成的
Looks like I guessed the correct machine.
http://nvidiasettlement.com/
完成的
添加一条评论
1个答案
最有帮助的答案
Just which version of the Apple MacBook Pro (15- 17-inch) May 2007 – September 2008 do you have with the Nvidia GeForce 8600M video processor? Is it that hard to hook up to a external monitor to get a free replacement logic board? Would you please give me the last three letters of your serial number so I can confirm your exact machine and we may not have to have the external monitor.
这个答案有帮助吗?
得分 1
2条评论:
good answer +
完成的
+ good answer....I just had a 2.4Ghz MBP with the Nivida card issue. Fixed for free under apples extended warranty for the recall they have. So it's worth checking out if your machine qualifies for the recall.
完成的
添加一条评论
添加你的答案
madmaxmedia 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 10
过去 30 天: 10
总计 957
