跳转到主内容
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
423 个问题 查看全部
locked out of my tablet rca RCT6303W87
someone put a password on my tablet and I am now locked out of it please help me to fix this so I could get back in ......
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
5条评论:
its a pin # i need
完成的
Unfortunately unless its giving you a reset option like signing in with your google account then a factory reset may be the only way to get back in.
完成的
Yes i did I can't rembere it
完成的
* But I need help lock out
完成的
I forgot my screen pattern so now I don't know what to do because I've been trying to remember the past my password but it happened didn't work so now I can't go all my tablet and go back into the tablet so I could change it into something I can remember
完成的
添加一条评论
2个答案
This video should help.
https://www.youtube.com/watch?v=ttvFDFqH...
If you do not want to loose your pics and files then you can log in with your google account that you have assigned on the tablet from a computer and use Android device manager to lock the device with a new code and then you will be able to unlock it. Hope this is helpful.
https://www.google.com/android/deviceman...
这个答案有帮助吗?
得分 0
添加一条评论
Um just factory reset it by turning power off and holding the power button and volume + up/down then ur be at android recovery factory reset it then sign I. To ur original google account amd ur be goood if u know it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tammy George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 2,882
