跳转到主内容
加入维修社区 - 创建账户
My Retina Screen is behaving erratically
The screen has a LOT of white lines crisscrossing the screen which de-mark individual pixels which make it quite unappealing to watch movies,etc.
Also when the mac starts up - sometimes (quite often) there is a green imprint in the middle of the screen that adds the colour green to every colour on the screen, but this goes after like about 5 minutes. If I view the screen from the sides I can clearly see the green imprint very clearly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
To try to isolate the problem, hook it up to an external monitor and see if the issue persists.
Next, start up in Safe Mode (hold down the shift key on start up to see if it might be software related).
这个答案有帮助吗?
得分 2
4条评论:
Thanks for your quick reply, but I have checked and it seems to be a hardware fault.
完成的
Hook it up to an external monitor and see if the issue persists. If so the problem is with the GPU. If not then you go to the display.
完成的
hello, i think i may have the same problem. display is ok on safe mode, but if i boot it in a normal way i also have a white screen with criss cross thingy, i hook it up to an external monitor and also the same output. is there a way to replace the gpu? Thank you!
完成的
It it's OK in Safe mode it is likely a software problem. Run a good "Paid For" anti-virus program like Symantec first.
完成的
添加一条评论
添加你的答案
Anshuman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 199
