跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
My screen has a speck on it?!?
So I generally keep my MacBook in very good shape, but the other day I noticed a little speck in the middle of the display. I ran my fingers gently over it and felt something (so it's not a drop of water or something). Between the keyboard and palm rest I also found a little piece of something, which I scraped off (this is approximately the same position as the speck on the screen). I don't want to scratch at my displya trying to get something off, for fear of damaging it. Is there some way that I can:
A) Determine whether I can safely "remove" this speck, and
B) If it is an indentation or other mark on my display, can I fix it without replacing the whole display?
All help is appreciated, and thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Spray a little Windex on a very soft cloth and see if it will dissolve.
Update: If the speck bothers you that much, here's the guide for replacing the screen: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
这个答案有帮助吗?
得分 3
9条评论:
Thanks for the suggestion Mayer, however this did not resolve my problem (although I haven't cleaned my screen properly in a while, so it did make the screen cleaner overall). After a few minutes of rubbing at the spot, it is still there. Any other ideas? I think I remember hearing that Vaseline could be used to fill in nicks in this type of display, although I can't verify that it's a good idea or not.
完成的
I really wouldn't put something like vaseline on my screen as it would attract dirt. Try using a magnifying glass to see what it is.
完成的
It looks like it's a small indentation. It's darkening the pixels in about a 3x3 range, which makes it quite visible whenever I work. Any ideas?
完成的
Look on the keyboard to what's sticking up to high and causing the indentation.
完成的
There was a piece of something there before, I scraped it off already.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Adam Hintz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 18
总计 2,101
