跳转到主内容
加入维修社区 - 创建账户
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Phone won't turn on at all
My phone froze on the "Samsung logo" start-up screen and did not want to shut off with just the power button. I held the power, home, and volume buttons to boot into Recovery Mode and it did. I chose to boot it up normally but then it froze on the Recovery Mode screen. I held the power button down to shut it off then it didn't want to turn back on so I plugged it in. When I did, a green screen was displayed with some OS options, so I chose to start it up with the existing OS. Now it doesn't want to turn on at all and doesn't show the battery screen when charging. Please help. Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Download and install Samsung Smart Switch on your PC. Connect your phone via USB, then choose "emergency firmware flash". The software will do all the work for you.
这个答案有帮助吗?
得分 2
3条评论:
Link to this Smart Switch?
完成的
http://www.samsung.com/us/smart-switch/
Saved my tail a few times. Its their replacement to Kies and its much smaller and easier to use.
完成的
Thanks for the info, going to test out this program.
完成的
添加一条评论
Can you still boot to download mode or boot to recovery mode once again? If you get to download mode (by holding Volume Down, Home and Power keys at the same time) you could try reflashing the firmware without losing your data.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Randy P 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,890
