跳转到主内容
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
Why is my Roku 3 not connecting to WiFi?
My Roku 3 is not connecting to the internet in my house.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
My Roku 3 fell into water. It does not respond now so I can't use home and OK buttons. Is it fixable? I put it on my air vent to dry. No evidence a place to take off the cover. Is it fixable or is it cheaper to get new one? Only the controller doesn't work.
完成的
My roku will not work. Light just blinks.ipluged into all ports and nothing only a year old I want it replaced
完成的
添加一条评论
5个答案
最有帮助的答案
If your network is a private network, make sure that the network password is correct.
Try moving closer to the router or remove as many objects from the path of the router to the Roku.
For a more in-depth troubleshooting guide, visit the WiFi section of our troubleshooting page.
这个答案有帮助吗?
得分 1
添加一条评论
Open your Roku device and select the wifi connection setup. Enter the password of your home wifi to setup the wireless connection. There will be the indication of 3 green check marks to finish the setup. If it fail to get 3 green check marks, repeat the steps
这个答案有帮助吗?
得分 0
添加一条评论
Try the following steps:
·        Connect your Roku box or stick to your TV and power ON.
·        In the very first screen, Choose ‘Wireless’ if you are going to connect via go.roku.com/wireless.
·        Roku will search for the network connection, select your network and finish the process till you select the option ‘Connect’.
·        After this step, your Roku will automatically show you the updated software.
·        ‘Download’ and install it to complete the '''Roku wireless setup''' process.
Hope, this will solve your issue.
这个答案有帮助吗?
得分 0
添加一条评论
Roku not connecting to WiFi !
hen trying to connect to the Wifi, the Roku device shows you a list of all available WiFi networks. You need to pick your network and then type in the password for your WiFi. However, sometimes the WiFi might not connect or Roku players that have been working fine in the past might start showing “Not Connected” on the home screen. These devices would then give you an error code when trying to connect to your wifi. So, if your Roku is not connecting to wifi, here is a list of all Network related Error Codes followed by best practices on how to resolve the Roku Error Codes and finally resolve roku not connecting to wifi issue.
这个答案有帮助吗?
得分 0
1条评论:
How do I go to the network it want let me go on the network it stops me we’re it us about
完成的
添加一条评论
for one why you charge 1.00 dollar to try to get your Roku fix I haven’t had know Enternet for 3 days now I am trying to figure out what is going could you help me please
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isobelle Espiritu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 25
总计 1,874
