跳转到主内容
加入维修社区 - 创建账户
支持汽油动力和电动高尔夫球车,有时也指 Club Car Golf Cart 品牌命名为高尔夫球车或俱乐部车。
EZ GO charger flashes 2 red lights
EZGO cart recently died after 20 minutes of operation. Pushed home and plugged the charger in and it flashed 2 red lights. Could the charger be bad?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have brand new batteries and I have tried 2 different chargers but the red light is still blinking red twice. What should I do?
由完成的 分享
添加一条评论
6个答案
已选择的解决方案
Paul, 2 red flashes, may mean battery voltage may be too low to take a charge. there could be connection problem (clean and tighten), defective charger. You can check voltage of each individual battery and if you you find a low one, try trickle charging that battery to bring it back with smaller auto charger with appropriate charge voltage. The local golf could probably verify if the charger is the problem.Good luck.
LInk below will explain charger light/diagnostic codes further.
http://www.golfcarthotrod.com/298/powerw...
这个答案有帮助吗?
得分 8
5条评论:
So, what is the "connection problem?" Clean and tighten what? I'm having this same issue and my batteries are fine. Any help would be greatly appreciated.
由完成的 分享
Same issue,...bought a trickle charger, disconnected the batteries( TAKE PICTURE), charged each one separately to 75%..Then connect everything, plugged regular charger in, and it's a GO! Thank you.
由完成的 分享
Same issue. Cleaned all connections and measured voltage of 50v. Briefly got a single red blink. Then it went back to 2 reds.
由完成的 分享
I'm getting two red flashes from my EZGO charger. I used a car charger and charged two 6 volt batteries at the same time. I tried the cart charger again, same fault. I bought another charger and charged the batteries to 100 percent. I tried my EZGO charger again and got the same fault code. I opened the charger and i have 120 volts AC coming in and just under 36 volts DC coming out. So, I don't have a clue why I'm getting a fault code. I installed new batteries in Nov 2020. Twice rather than adding water, I added battery acid and twice I've added distilled water. The batteries look pristine and all connections are tight. Any idea?
由完成的 分享
Saludos:: tu cargrador debe de proporcionar aproximadamente 37.5V a 38.5V ´para que pueda cargar las baterias correctamente voltaje nominal de 37.5 , si tu banco de baterias es de 36v, mas bajo de ese voltaje no cargara y te dara codigo de error que son los 2 destellos de led rojo.
由完成的 分享
添加一条评论
I have seen a few posts where the light on the charger flashes rapidly 5 or 6 times and then goes out. I had this problem and finally figured out that the breaker for the wall plug had tripped and AC was not on. Apparently even without power the charger will still flash when it sees some DC power from the batteries when you plug the charger into the cart.
这个答案有帮助吗?
得分 1
2条评论:
Several chargers have gone red on a fleet that I take care of. Tryed everything to do d problem. No luck.
由完成的 分享
This is exactly what happened to me. Problem fixed.??
由完成的 分享
添加一条评论
I have a exercise go cart and the charger is flashing red twice. It says it’s a battery charge fault. My question is if I leave it plugged in will it charge. I cleaned, wire brushed all terminals and link wiring. Replaced and made sure everything was tight. Will it charge using the charger or do I need to try to charge each battery individually
这个答案有帮助吗?
得分 0
1条评论:
It was supposed to say Eze-go
由完成的 分享
添加一条评论
I have a 2007 ezgo golf cart red light flashes two times on charger
这个答案有帮助吗?
得分 0
1条评论:
I have the same thing, did you figure it out? New batteries, new and/or clean terminals but 2 red lights on charger. 49.2V measured at charging receptacle on golf cart. Do I need a new charger?
由完成的 分享
添加一条评论
Same issue. Cart won’t move but the dump bed works fine 😵‍💫
这个答案有帮助吗?
得分 0
添加一条评论
Replace all batteries three weeks ago. Was working like a charm with VERY tight and clean connections. Woke up this morning to a non-charged cart and two red lights flashing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 80
过去 30 天: 466
总计 93,869
