跳转到主内容
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 个问题 查看全部
2nd microphone not working
I did an LCD replacement on a phone I bought, I couldn't test before so no idea if it worked before but after finishing everything I noticed a small rip on the cable so I replaced it. I replaced it with another one and that didn't work either so I replaced it yet again and still nothing
The microphone in camera works and the microphone for google now
I am not sure if google now uses primary or secondary microphone (bottom microphone)
anybody have any ideas which is what or what the problem could be
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Does microphone work during calls? If not that's the bottom microphone which I'm pretty sure is part of the power + volume flex cable that also connects the LCD.
If it doesn't work on video record then it could be the other microphone which is connected to the headphone jack assembly.
这个答案有帮助吗?
得分 2
1条评论:
yes that is the flex cable. i can not test if it makes calls or not due to not having an active sim for this carrier
完成的
添加一条评论
添加你的答案
David F 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 2,300
