跳转到主内容
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60 个问题 查看全部
Can I solder broken wire back on using the old solder blob?
Hi! My headphones broke on one side. I can see the broken wire inside the ear cup and was wondering if I could just melt the solder that's there and push the wire back in. (after snipping the wire). I've never soldered before and don't know much about electronics.
Here's a picture, you can see where the wire's all broken.
https://postimg.org/image/6fcajabhl/
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Christian, as Shelton stated could be possible, but if you want a good clean trouble free repair at least get a little flux/rosin cored solder so you will have a clean soldered connection, saves from having to do it twice.
A small amount of rosin core solder can be purchased at most electronics stores and big box stores as well.
Below I will post a tutorial on soldering. Good luck.
https://www.youtube.com/watch?v=Qps9woUG...
这个答案有帮助吗?
得分 4
添加一条评论
Should be possible, your picture isn't the clearest though. Before of your temp when soldering you don't want to melt anything. Maybe watch a few basic videos on youtube before you try.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 3,239
