跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1169 个问题 查看全部
no service, "wing" on the logic board is broken
Hey guys,
unfortunatly I broke the little golden "wing" (is it for grounding or increasing antenna signal?) near by the 'do not remove' sticker.
Please let me know whatfor it is and how can i fix it (no signal)
Thank u,
cheers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
That'd be part of the antenna! Bottom of dock is one, silver bezel on display is also one joined to logic board by gold prong. You can scrape a little of the film from square on logic board where prong came off then solder prong on.
这个答案有帮助吗?
得分 2
添加一条评论
Glue the "wing" back to the board and make these two pathes:
http://www.mauron.net/iphonerepair/last_...
"You should first glue the corner so it is tightly fixed to the motherboard, and afterwards restore the electrical continuity between the antenna contact pad and the track going to the small coax connector, as well as between the small grouding "spring" and the motherboard ground as in the picture below."
HowTo:
"You would need to solder two wires. The first from the antenna pad to the track as explained in full details above. And the second to connect the grounding contact (the one you can see all the way left in the first picture, which gets pressed against the metallic frame when the board is sitted in place) to the board's ground."
(From: http://www.mauron.net/iphonerepair/)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
louis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 4,833
