跳转到主内容
加入维修社区 - 创建账户
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
LCD ribbon lockdown device.
The lock that secures the ribbon (the plastic flap) broke off while trying to pry it up.
Will it work without the lock?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You could try to place teflon tape on top of the ribbon before plugging it in to try to allow the pins in the female connector to touch the lcd flex. Other wise you would need to send that out for service.
Otherwise you'll need to have it repaired professionally. I have had great experience with this ebay based business:
http://www.ebay.com/itm/iPad-3-4-LCD-FPC...
这个答案有帮助吗?
得分 0
2条评论:
thank you, it worked. Now I am back to the original problem. as soon as I hit the main power button all I get is a picture of a battery for about 2 or 3 seconds and them it flashes once and goes blank.
完成的
Sounds like that is a charger issue, try a new cable and brick. If that doesn't work then it is more than likely the battery.
完成的
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 68
