Why is my vacuum spitting out dirt?
My vacuum started spitting out dirt from the front onto the floor. Any help is appreciated.
Thank You
First, make sure there isn’t a clog in the vacuum. There are three places where clogs are most often found: behind the brush roller, the hose, and the dust cup air duct. Also, you might need to clean the HEPA filter. If the filter is dirty it could prevent the vacuum from blowing out any air which could be the reason the vacuum is blowing out dirt. The steps to check for clogs can be found in the troubleshooting guide and the HEPA Filter replacement guide.
这个答案有帮助吗?
I am experiencing the same problem so I decided to take it all apart. Found that when their is a clog the dirt gets pushed past the filter and into the motor “FAN”assembly. Every time I turned it on it blew dust. After I cleaned out the motor/fan and rinsed the filter problem when away. My recommendation is to run it outside until no more dust, clean the filter or replace and keep maintaining it after every use correcting clogs as they occur. No simple answer use, clean, store.
这个答案有帮助吗?
I have no idea how to take my shark rocket apart. Litter is dumped all over the carpet I just vacuumed!
It turned out my filter was clogged on the inside (inside the compartment where the debris collects, right in the middle of the vent passageway). I had already cleaned out the compartment but turns out inside it was still blocked in the air passageway. I carefully cleaned it out and poof! the vacuum cleaner started working beautifully again. It's always a good idea to take it apart and look for clogs anywhere.
这个答案有帮助吗?
One day, while vacuuming my living room, I noticed it started spitting debris back out. Panic set in! I turned it off, and checked the dustbin. It was full to the brim. I emptied it and then took a look at the filter. It was clogged with dust. After giving it a good clean and removing blockages in the hose, my vacuum was back to its old self, efficiently picking up dirt. Remember, a regular check-up can save a lot of hassle. You might get more value here, I found it much informative for me.
这个答案有帮助吗?
Thanks, John John! It worked for me as well
过去 24 小时: 38
过去 7 天: 263
过去 30 天: 1,235
总计 91,107
1条评论
My shark rocket vacuum is shooting dirt back i can feel it hit my feet and bought new filters and clean brush and took apart to check for clogs and unclogged in the main tube and it is doing it still , I'm ready to throw vacuum out.. Any recommendations would be appreciated thank you
由 Karen Whitman 完成的
