跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 个问题 查看全部
问题已关闭
CPU Upgraded, do I need to reinstall OS X?
I have just upgraded my core solo to a core 2 duo (Thanks Guys!). Coming from the Windows world, I know that I would need to reinstall my OS otherwise funny things happen. Should I re-install OS X at this point ? (Been upgraded from 10.4 through 10.6.4, so it maybe time anyways...)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I don't think so. I've installed hard drives from diierent machines and different systems into other Macs and as long as the Mac could operate under that system, I've never had a problem.
这个答案有帮助吗?
得分 4
4条评论:
works for me +
完成的
yup, no need to reinstall.
完成的
The answer is: Yes, you should do a clean reinstall. After reinstallation, things like 64-Bit apps, additional app speed (Handbrake, which is my main benchmarking app as it can turn any CPU into a drooling mess) and stability increased. Now, the issue of was the CPU upgrade the cause or the symptom, I do not know. I suspect it was a little of both.
完成的
I just did this upgrade and will let you know if I have any problems. But to be safe, it couldn't hurt.
完成的
添加一条评论
it's not be necessary to reinstall
(but you can passe in 64 bits if it's possible for the CPU
这个答案有帮助吗?
得分 0
1条评论:
Due to what I was upgrading from, the answer is YES. I went from core solos to core 2 duos. GCD handles differently w/out the multiple cores present if it installs at all. Anyways, I will agree that in most cases the answer is a resounding no. Except I am/was in an edge case where the answer is yes.
Thanks,
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 1,621
