跳转到主内容
加入维修社区 - 创建账户
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Kenmore Sensing and Lock Issue
I have a Kenmore top loading washing machine; model number 26002010. The other day my wife started the machine and then quickly realized she needed to add more clothes and opened the lid prior to the second unlock/relock cycle. Ever since the washer will start flashing a lid lock error and it will make a strange sound and emit an electrical or plastic like smell. Once in a while I am able to get the washer working by unplugging and re-plugging the washer back it or letting the load machine start empty or by wiggling the lock mechanism. As long as the water starts running into the machine the machine works as expected with no issues. Any idea what is happening and how I can fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Replace this part:
Kenmore Washing Machine Door Lock W10404050 Whirlpool Top Load Washer Lid Latch Assembly - W10404050
Prevents the washer lid from opening during wash and spin cycles by locking it securely.图片
产品
$45.99
这个答案有帮助吗?
得分 2
3条评论:
Unfortunately the issue persists even after replacing the part. Looking at replacing the shift actuator now.
完成的
Were you able to solve the issue? I'm having the same problem with my Kenmore washer.
完成的
Same problem here.
完成的
添加一条评论
I unplugged the machine for 10-15 minutes then restarted it. It clicked off again at first but then started. Patience is the key here!
这个答案有帮助吗?
得分 0
1条评论:
i have a kennmore 500 series washer and i was smashing maybe to big of a load and it stopped now wont start it flashes 5 times and the lid stays locked o cant even get my clothes to wash them somewhere cause the lid is locked
完成的
添加一条评论
添加你的答案
Matt Ailstock 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 7,380
