跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Phone doesn't vibrate or show any signs of life when plugged in.
I dropped my IPhone 6s and smashed the screen, a few days later the phone stopped charging and refused to show any signs of life. I opened the phone up and tried to see what was going on, however I am only a beginner and couldn't figure what was wrong with the phone. One of my friends mentioned that the Touch Ic chip may be broken, does anyone know how to determine if that is true?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Touch IC is for the touch screen functionality of the phone. The phone should still turn on and show display even if that was faulty.
Chances are that the battery could of been damaged from drop.
完成的
Agree. Probably not the touch IC. It is possible that the battery is bad or simply that the battery connector got knocked loose. Its also possible that one of the fuse/filters go knocked loose.
完成的
添加一条评论
2个答案
I you're under warranty or an insurance plan contact your provider. If not and you want to do a self repair, try first disconnecting the battery, do not reconnect, and disconnect the LCD cables from the board and reconnect them. Reconnect the battery, and plug the phone in. Try that.
这个答案有帮助吗?
得分 0
添加一条评论
Personally I would reach out to apple support
这个答案有帮助吗?
得分 -2
1条评论:
This is a place where we try to help each other fix issues, not tell people to call Apple.
完成的
添加一条评论
添加你的答案
Ethan Paterson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 121
