跳转到主内容
Xbox One Controller 的维修指南、手册和故障排除帮助。获取自己维修 Xbox One Controller 所需的一切。
How to fix triggers squeaking?
My right trigger squeaks when pressed.
The only fixes i can find are to put oil in it or blow on it wich are both temporary fixes.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Jayden, spray trigger with silicone lubricant while working trigger to allow lubricant to work into slide area, wipe trigger surface clean and give it a try. It should hold up for quite a while. Good luck.
这个答案有帮助吗?
得分 3
4条评论:
Thank you - i had to go out and get some silicone lubricant since the only thing i had on hand was WD-40 and thats a bad idea lol but i took the controller apart and used a small brush to sort of paint the oil onto the springs in the trigger and they are flawless now.
My squeaky Nightmare is over!
完成的
That is great Jayden, thanks for posting back.
完成的
I know I'm late to this and WD-40 is a bad idea to use on a controller, but what about the silicone lubricant that WD-40 make? Would that be of any use or is that still a bad idea?
完成的
WD 40 is mineral oil in suspension. The carrier agent are solvents that are polymer safe mostly. The issue is the amount people usually use, which is too much. Once the solvent evaporated, the oil is left ideally you want a micron thick film on the working parts, no more than that or it'll start to gunk up with dust overtime. Silicone oil will do the same if you apply too much of it.
完成的
添加一条评论
添加你的答案
Jayden Waters 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 95
总计 16,064
