跳转到主内容
The RIDGID R86034 is a Lithium Ion impact driver manufactured by RIDGID in 2012.
Will not switch to impact mode
The drill will not switch to impact when drilling
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Steve, If your drill is indeed switchable and not just a impact driver, if the hammer mode switch feels sloppy or to easy to switch, the switch has came out of position or broken a tab inside drill. If switch seems normal but you are not getting hammer mode the wing disc and gear could be seized, worn or broke. I will post a link, not your model but should be similar to show how the hammer function works and the common components. Good luck.
http://www.finehomebuilding.com/2010/02/...
这个答案有帮助吗?
得分 2
1条评论:
If Steve is, in fact, referring to a Ridgid R86034, it is not switchable, it's just an impact driver. FYI for all
完成的
添加一条评论
添加你的答案
Steve Muller 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 448
