跳转到主内容
加入维修社区 - 创建账户
The TomTom GO 500, 2014 edition is a portable GPS navigation device that features an interactive touch screen, 3D map visuals, voice command, lane guidance, and live map and traffic updates provided through smartphone connection.
Why does my device's touchscreen not respond?
The touchscreen does not recognize any of the key that I press.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
The screen will not activate when touched
完成的
The touch screen does not respond on the left side at all
完成的
添加一条评论
2个答案
This problem may be caused by a faulty digitizer. Try tapping various parts of the screen. If the device is only registering commands at certain parts of the screen, registering incorrect commands, or not registering at all, then the digitizer may need to be replaced.
If the device's screen is cracked, then this problem may not be caused by a faulty digitizer. A cracked screen may indent the structure of the device and unintentionally apply pressure to the digitizer. To overcome this pressure, the digitizer will need hard taps. Normally, the digitizer will respond to soft taps. Replacing the screen may fix this problem.
Check out the troubleshooting guide on this device for more information: TomTom GO 500 Troubleshooting Guide
这个答案有帮助吗?
得分 0
添加一条评论
problem in the screen. Change the sensor. I had the same problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicholas Maharaj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,889
