跳转到主内容
Can the LCD be replaced?
Is it possible to remove the bezel around the screen to access the LCD? If it is glued on, would a similar heat-gun method as needed for the recent Macbook Pros work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Can anyone tell me what the part number is for the LCD panel. I'm trying to find a exact replacement.
完成的
weidyc, it would work better for you if you click on the link on the right side of this page "ask a question" and give as much detail as possible. I also believe that the apple guru's always ask for the serial numbers...anyhow give it a try and I am certain you will get a quick response. Good Luck
完成的
添加一条评论
3个答案
已选择的解决方案
Best NOT
to use a heat gun... see How to Replace the Macbook Air Hinges and LCD - heat can deform the rubber trim.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 1
1条评论:
Thanks! Sorry, should have checked earlier revisions of the Air line for the answer before asking.
完成的
添加一条评论
最有帮助的答案
No, the whole machine has to be taken apart!
这个答案有帮助吗?
得分 1
添加一条评论
lutris you can remove the bezel and change the led from that . i have also changed the led . see the link :
http://www.youtube.com/watch?v=eHNtnvzfS...
be patient thnx
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lutris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 5,501
