跳转到主内容
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
Why doesn't my eMac start up?
Apple eMac G4 start up problems
Hi!
I recently received an eMac knowing it was faulty and wish to try and fix the problem!
I press the 'power on' button, it chimes, then accesses a white page with the apple logo and spinning sign and finally gets to the stage of 'starting Mac OS X...' but won't go past this page even after leaving it for nearly an hour.
Any solutions are welcome!
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Please identify your machine for us here are the eMacs:
http://www.everymac.com/ultimate-mac-loo...
完成的
添加一条评论
1个答案
已选择的解决方案
Without knowing your exact machine I can not tell you the range of Mac operating systems it will take. That given. all will run 10.4, Best if you have the original system installation disk. Insert the disk, restart and shove the disk back in and hold down the "C" key. Go to the second page and the pull down menu will appear. Go to disk Utilities and run Disk Doctor and see if you can repair the hard drive.
Either your system is corrupt, has the wrong system or hard drive has gone bad.
Disk Utilities failing, I would then reformat the hard drive (using the "write zeros option, to map out any bad blocks), Then reinstall a new system.
If you do not have the installation disk, you will need to give us your exact machine. That information should be printed on the back or bottom of the machine. Then we can direct you to the correct system to install and where to get it.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mgeri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 613
