跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iTunes error code -1
An old phone form my friends needed restoring as it had a passcode. Everything was working perfectly fine before except it didn't charge, turns out there was a lot of crap in the charging port so when I cleaned it out it charged and worked perfectly
When I went to restore it gets halfway through and returns error -1
i can't seem to find any info about this erorr online
does anybody have any ideas? only thing I can think of is charging port
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Charging port sure sounds like a good possibility.
I gave up on using iTunes error codes to diagnose problems. I would believe it if you told me that they are completely random and mean nothing. Start simple: connect a new Lightning port to the board, connect to iTunes and see if it works. Don't worry about taking the old one out or doing anything fancy. Just plug it in. If it works, you are golden. If not, you only lost about 30 seconds.
这个答案有帮助吗?
得分 1
2条评论:
I tried it still the same unfortunately. It just crashes and stays with the bar there and the apple logo and returns -1, it will only go away if I unplug or restart
guessing it's toast, very annoying as it worked fine beforehand
thanks anyway
完成的
I suggest attempting a DFU restore if you haven't already.
Has the battery been replaced before?
完成的
添加一条评论
Well, what do you know...
Took it out of the housing and just had battery and charging port (no screen) didn't work, tried with screen, didn't work...
I thought I'd give it a bath with IPA99. Didn't ultrasonic clean or even remove IMEI shields as I can't at the moment but what do you know it worked and the device is fully restored
No visible signs of water damage
这个答案有帮助吗?
得分 0
4条评论:
ship it!
Then keep researching for when it comes back with the same problem :D
完成的
and it's back with the same problem lol
doesnt get calls, just says searching or no service so I restored it again and updated and what do you know itunes error -1... so i did the same thing and cleaned it in a bath of IPA and let it dry and it restored again and signal was great until this morning now it has stopped. any ideas what the actual problem is?
完成的
I'm fairly sure this is a baseband chip fault issue as it's intermittently working. I'm not sure whether it needs to be reballed / reflowed or replaced.
You probably see that the IMEI and modem firmware may disappear together in Settings > General > About phone when it gets the searching and no service.
完成的
In my opinion it is hardware issue which can be resolved by reflowing the chip (easy version) or more complicated reballing or replacong the chip.
完成的
添加一条评论
It's a hardware problem as said before. Some have worked to heat around simcard tray with an hairblower for 4-5min
这个答案有帮助吗?
得分 0
添加一条评论
Error -1 could be caused by connection between device and pc, network and hardware problem.
这个答案有帮助吗?
得分 0
1条评论:
Error -1 is a baseband IC connectivity issue. Reballing the Baseband IC is the best way to fix it.
完成的
添加一条评论
添加你的答案
David F 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 528
