跳转到主内容
Repair guides and support for the 2nd-generation Renault Mégane, also known as the Renault Mégane II.
Why do warning lights stay on when engine is running
why do warning lights on dash stay on when engine is running
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi, Which warning lights are staying on?
完成的
添加一条评论
2个答案
已选择的解决方案
Norman, see the attached links for various warning lights and why they may be on. In some makes a lot of warning lights may come on and stay on when battery is faulty or charging system fault if both are tested and found to be good, you will have to have a good technician have a look, diagnose and estimate repair. Cluster or PCM could be faulty and not communicating correctly to one another. Check the attached links,instruction and guides, Good luck.
http://www.autozone.com/landing/page.jsp...
http://www.precisiontune.com/our-service...
https://www.theaa.com/breakdown-cover/ad...
这个答案有帮助吗?
得分 1
添加一条评论
Last week I am visiting at http://universalmotorcarslv.com/ they guest are best
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
norman rushton 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 1,662
