跳转到主内容
加入维修社区 - 创建账户
Garmin 于 2012 年 2 月发布的触摸屏 GPS 设备,具备自定义兴趣点和实景路口导航功能。屏幕对角线尺寸为 4.3 英寸,分辨率为 480x272。
Why Won't My Touchscreen Work?
My device will turn on but when I press the screen to make any commands I can not prompt any response. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are three possible problems that are associated with an unresponsive touchscreen. They are listed from easiest to hardest to complete.
Dirty Screen:
  • If your device has a screen protector, remove it
  • Spray a bit of water or formulated spray onto a microfiber cloth.
  • Wipe thoroughly.
  • Using another dry microfiber cloth, immediately dry the surface.
  • Replace the screen protector with a new one if desired.
Resetting the Device Without Using the Screen:
  • With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit on while maintaining pressure in the bottom right corner. When you see a prompt asking, "Do you really want to erase all user data?", you can release your finger and select yes.
  • If the bottom right of the screen is unresponsive then please refer to the broken screen guide.
Broken Screen:
  • If your device screen is still unresponsive after following the following guides above please refer to this guide for replacing a broken screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathaniel Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 24
总计 808
