跳转到主内容
加入维修社区 - 创建账户
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
Video problem - installing shim
Newbie here. What instructions do I need to follow to try and install a shim before I get new logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Could you give a better description of why you want to install a shim?
完成的
添加一条评论
1个答案
已选择的解决方案
It's not hard
you just dismantle until you get the bottom off.... then shim over the Square you'll see pressed in the foil opposite the optical drive. You can affix the shim to either the foil or the case.
In my experience sometimes flame works when/if shimming fails... all these "work arounds" are temporary life prolonging "fixes".
only reflowing or replacing the VGC is a long term fix... but due to the cost it's becoming less and less cost effective.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,375
