跳转到主内容
The Toshiba Encore WT8-A is a touchscreen tablet running Windows 8.1.
Why won’t my device turn on?
My device will not turn on even though I hold down the power on button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
Student question
完成的
添加一条评论
6个答案
Your device’s battery might be dead. You may simply need to charge the device, however if your device has been plugged into a charger and is still not getting a charge, you may need to replace either the charger, or the battery, or both.
这个答案有帮助吗?
得分 0
2条评论:
I have the same issue. Measured battery voltage and just sits around 3.2v. Ive notice the battery stats show it should be 3.75v. Does this mean the battery wont charge at all? Ive had it plugged in using various chargers and cables to no avail.
At one point toshiba logo appeared on screen before disappearing and then nothing.
Is this potentially a charge port issue? Or flat out battery.
完成的
@zarmstrong do you guys get credit for answering your own question? just another thing to note is that if a battery wont charge and tablet wont boot you can disconnect the battery for a few minutes and reconnect . This often brings joy
完成的
添加一条评论
This toshiba made tablets are very poorly made product made in a Chinese sweat shop by little 10 year olds trouble do not buy any thing toshiba !!!
这个答案有帮助吗?
得分 0
3条评论:
My problem is that the power button on my toshiba tablet wt8-b is stuck and won't come back up - have tried to push it down in the hopes that it will come back up but it did not
完成的
Used a cuticle clipper to push it down but it didn't work - where can i buy a replacement part for the power button on my tablet?
完成的
Yes yes not buy anything from TOSHIBA because they made the military grade laptops for US Army. Keith Roby how old are you ?
完成的
添加一条评论
If battery life is not the problem, a soft reset may correct the “won’t turn on” issue. Hold the VOL- (volume down) button while pressing the power button. This will put the device into RECOVERY MODE. Sometimes just entering recovery mode and exiting is sufficient to correct your issue.
这个答案有帮助吗?
得分 0
添加一条评论
My tablet just flahses and after a bit when I wait it turns on then goes black.
这个答案有帮助吗?
得分 0
1条评论:
Can anyone help please because I cant afford anything else. Any suggestions please??
完成的
添加一条评论
Hold the power button 45 seconds
这个答案有帮助吗?
得分 0
添加一条评论
Why does the Toshiba tablet does not want to onn
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zachary Armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 10,075
