Re-Install OS error to newer version OS
Hi all,
I want to re-install my OS on my MacBook. I went into Disk Utility using the command key and R. Erased the harddisk and tried to install the new OS (10.10) but I got this message after entering my Apple Id: this item is temporarily unavailable.
I tried the internet recovery using command+option+r and this worked, but it was installing OS X Lion. I wanted the newer version.
When I now try to recover using command+R, I automatically come into internet recovery.
How can I install the newest OS X for my laptop?
Thanks in advance!
5条评论
What was the reason you wanted to do a re-install? You may have a hardware issue, like a bad HD/IR cable. Do you have access to another Mac? An external hard drive or flash drive on which you can store an installation download?
由 mayer 完成的
@mayer The mac was working good but I am using a mac os for the first time so I wanted to try to format it. It is now installing OS X Lion, but it says 10 hours to go...?!
由 Uas 完成的
How fast is your internet link and where are you on the big blue marble? You maybe hitting the limits of the connection which is just very slow.
由 DanJ 完成的
I plugged in an ethernet cable and it was really fast. Now OS X Lion is installed. I want a newer version. I saw a new version Sierra is out, but should I use this OS or use Yosemite?
由 Uas 完成的
Here's your systems specs: MacBook Pro 15" 2.2 GHz i7 (Late 2011)
由 DanJ 完成的
