How do I clean my fan properly?
I think my fan has dust in it; how do I get the dust out?
Julia, While computer apart do not just clean the fan, clean every thing you can using a can of compressed air, this will ensure proper cleaning and reduce damaging heat build up on internal components. I will post links that will help you see how to disassemble laptop and instructions on cleaning. Check the attached links,instruction and guides, Good luck.
http://www.howtogeek.com/194479/how-to-c...
这个答案有帮助吗?
You must first remove the fan cover. After that, use a can of compressed air and blow directly into the fan. Blowing into the fan via mouth will not remove the dust.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 1,875
