跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Fusion drive delete and configure 2x ssd in raid 0
i bought a macmini 6,1 late 2012 today.
It has 1 tb fusion drive and it works well but not what I expected as I planned to use a data doubler and plunk in 2 x 960 gb sata 3 ssd in raid 0.
Internet searches have me confused that the connectors are different with fusion drive installed.
Can I still go ahead with my project with just a data doubler and add 2 2.5"size ssd?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
完成的
添加一条评论
1个答案
已选择的解决方案
Yes! Your system can support two SATA HD or SSD drives!
Here is the kit you need: Mac Mini Dual Drive Kit which gets you the needed parts and tools to put in the second drive. And here is the IFIXIT guide you'll need to follow: Installing Mac Mini Late 2012 Dual Hard Drive Kit.
Are you sure you got the Macmini6,1? I suspect you got the Macmini6,2 Mac mini 2.3 GHz i7 (Late 2012) as it was the first Mac mini model which offered a Fusion Drive. In this series Apple used a 2.5" SSD.
If you got a newer 2014 then you'll have issues as it can't support two SATA drives. Instead it supports one SATA drive and one PCIe custom Apple blade drive. Here's the IFIXIT guides for this series: Mac Mini Late 2014.
If you review this Mac Mini Late 2014 Teardown jump to Step 5 while not present in this system the area just behind the fan is were the Blade SSD would be which you can see in Step9. In the 2012 models this would be a 2.5" HD or SSD. You may want to pop the bottom off to double check what you really have here.
Its also possible someone created their own Fusion Drive setup as well.
All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.图片
产品
Mac mini Dual Drive Kit
$26.99
Mac Mini Late 2012 双硬盘图片
指南
为您的 Mac Mini 2012 晚期款 安装双硬盘模组
难度:
中等
1 - 2 hours
Mac mini Late 2014图片
指南
Mac mini Late 2014 Teardown
难度:
中等
这个答案有帮助吗?
得分 1
1条评论:
Before you take any drive out you'll want to break the Fusion drive set first!
Follow the steps outlined here: How to split up a Fusion Drive
完成的
添加一条评论
添加你的答案
Kevin Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 618
