跳转到主内容
Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
89 个问题 查看全部
问题已关闭
carb won't fire unless I pull out drain plug
Okay so bike runs on one cylinder great! Both sides are getting gas, but the only way I can get one side to fire is spraying starting fluid in the boot or pulling the drain plug out of the bowl and if I do that it fires right up and stays running besides draining gas of course.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Brandt Gorsegner sounds like a float or needle valve issue. What model is your bike and/or your carbs?
完成的
添加一条评论
1个答案
最有帮助的答案
Brandt, remove carb/s ,clean/rebuild and start with fresh fuel. You can google search your year, make, model and engine for carburetor rebuild instruction if needed. Check the attached link for your repair manual,instruction and guide, Good luck
http://www.carlsalter.com/yamaha-service...
这个答案有帮助吗?
得分 2
4条评论:
So I did remove carbs today went through them good with a mechanic he's just not a motorcycle mechanic, put it back on and like I said that side just won't fire and stay going vaccume lines are pushing air but the gas on that one side is not going through like it should... has spark, has compression. I remove the drain on the bowl and it will start to fire
完成的
If the carburetor has fuel in it, pump if equipped working, and fuel is not getting to combustion chamber and float is not sticking and at proper level, the jet is plugged or pin stuck damaged, out of adjustment. Recheck for pinched fuel line, clogged filter, fuel vent in gas tank cap not clogged if equipped. Good luck.
完成的
Make sure throttle cable,carb. plunger/piston/needle installed and working properly. Check this link, hope it helps.
http://www.dansmc.com/carbs.htm
完成的
We have literally tried everything we can think of, checked lines, compression test, vacumme test, gas will come through the gas line and go into the bowl, both sides have good spark, could carbs be that out of sync? I have a sync tools haven't tried it yet.. we're running out of ideas like I said. We checked floats in carb also well we just actually went through the whole carb again everything looks fine! I am so lost
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 116
