跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
When turned off the fans keeps spinning. Is it normal?
The fans are normally very quiet but when i turn off the computer the fans of the thunderbolt display first starts spinning very fast and after 5 seconds keeps spinning not so fast but keeps running until I power on my computer again. Is it normal?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
ya it normal.
完成的
Like Colonel Hogan answered is not normal, and apparently it is a common problem
完成的
添加一条评论
3个答案
最有帮助的答案
Hi,
have you latest Thunderbolt Firmware installed ? Check Mac Software updates. There was an update adressing fan related issues.
Update (01.10.2016)
So, now i found this about the problem.
Seems to be an apple known problem.
https://discussions.apple.com/message/16...
这个答案有帮助吗?
得分 1
添加一条评论
Hi Colonel Hogan,
Thanks in advance for you answer.
Yes, i've already checked the updates. It is the last version of the firmware (26.2)
It is not normal right? For the thunderbolt display's fans starts when turned off.
这个答案有帮助吗?
得分 0
2条评论:
Have you attached external devices to the TBD ?
完成的
No, all the ports in the TBD are unused.
完成的
添加一条评论
I realize I'm incredibly late to the party here, but if you've got your MacBook charging even when it's off, the fans will cool the power adapter.
这个答案有帮助吗?
得分 -1
2条评论:
Sorry dude, Its a Thunderbolt display not a macbook that is having the problem.
完成的
yes, that's abundantly clear. in case you're unfamiliar with thunderbolt displays, they have built-in MacBook chargers. when said built-in MacBook charger is plugged into my Mac and charging, it creates heat. the fans inside my Thunderbolt Display turn on to keep the AC/DC conversion circuitry cool, even though the display itself is powered off.
thanks for giving ME a demerit for YOU not knowing what I'm talking about.
完成的
添加一条评论
添加你的答案
Kojiro Nagai 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 7
总计 230
