跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s stuck in recovery mode : Error 50
Hi. I am from Malaysia
I had error 50 on my iphone 5s two days ago. first i lost my network connection, then when i connected the phone to itunes to update to ios 10 the udate stopped half way and showed error 50. anyone can advise how to repair this problem since there are so many people with the exact problem around the same time. What a coincidence, lol
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
6个答案
已选择的解决方案
I would first try to force the phone into DFU mode and try again making sure the cable is original, the battery is holding some charge like 25% or more, and iTunes is updated to the last version.
If you have previous liquid damage or other physical damage that affected your board, it may fail all the restore attempts until the damage is fixed - if repairable.
To force the phone into DFU mode: connect it to the computer, with iTunes turned on.
Press & hold Power Button for 2 seconds;
After 2 seconds, keep pressing on the Power Button and simultaneously press & hold the Home Button (for iPhone 7/7+, the Volume Down button);
After 12 seconds, release Power Button, keep pressing Home Button (for iPhone 7/7+, the Volume Down button);
After maximum 15 seconds, release the Home Button (for iPhone 7/7+, the Volume Down button). iTunes on your computer must be by then showing a prompt saying an iPhone/iDevice in recovery mode has been detected. The screen on your iPhone/iDevice must be black with nothing showing on it. Otherwise you are in "Restore Mode" not in DFU mode, and should repeat the steps above.
Once in DFU mode, click on the option "Restore iPhone/iDevice" that you must be seeing as an option in iTunes. Leave it alone until it restarts on its own.
It may take up to a few hours to download the firmware from Apple, if your Internet connection is slow.
Once done, all your data will have been erased.
If you wish to (try and) retain your data, you may try a slightly different approach:
Turn off the iPhone/iDevice. Press & hold the Home Button (for iPhone 7/7+, the Volume Down button) and while holding, connect to your computer using your USB cable. The iPhone/iDevice will restart. Keep holding the button till it has restarted and showing "connect to iTunes" or the USB cable image on your screen. At the same time, iTunes on your computer should be saying that an "iPhone in restore mode has been detected" and you have the option to "Update" or "Restore." Try Update and leave alone till it restarts on its own.
Hope this fixes it.
这个答案有帮助吗?
得分 5
添加一条评论
I hope this article I wrote will help you with the solution.
https://bold.io/how-to-fix-error-50-when...
这个答案有帮助吗?
得分 1
添加一条评论
I too tried the hair dryer, pressing the power/home button while loading up and on its own but none worked. I read that the heat malfunctions something inside so I decided to rub my iPhone 5c with my hands until its hot enough (2 mins) and then stuck it under my hot laptop while it loaded. first time did work but second attempt did and loaded it fine! make sure your phone silent/loud tab is just on loud! good luck
这个答案有帮助吗?
得分 1
添加一条评论
the battery should be 30 percent and make sure the battery firmness connectivity going to logic board should hold firmly with the batt temp. and current sense of the battery terminal .. run a 32bit OS for windows 7..
and other ways...if it change the touch id sensor.. disconnect that wire when detected to the itunes upon processing ..right away...
这个答案有帮助吗?
得分 0
添加一条评论
save the old version of your i tunes.. when you restore old version...it makes a lot of help...
这个答案有帮助吗?
得分 0
添加一条评论
hello
using the hair drier worked for me .
but my baseband seems not working.
after inserting my sim card , it shows research....
however wifi works perfectly.
https://www.youtube.com/watch?v=rmRwWLf5...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
devienraj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 9,255
