跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Dont Know why has white vertical line on the screen
i'm no idea how this sad happen .I never dropped my phone or into water. Today when i'm reading novel the white line suddenly popup slowly. After that i try restart the line still leaving....why ....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
seng, take iphone apart and try reseating the cables, this may fix the issue. Check the attached links,instruction and guides on how to access cables , Good luck.
https://www.youtube.com/watch?v=vObeEEWF...
https://www.youtube.com/watch?v=oMQZv7bf...
这个答案有帮助吗?
得分 3
1条评论:
thank for your solution, i try unplug the connector of LCD and cleaning the socket but the problem still happening. so i try to replacement the LCD and all problem is solved. So i think the ribbon of LCD is already damaged. However thank for your reply XD
完成的
添加一条评论
It's usually damaged ribbons or the screen connectors aren't pushed on correctly. The May need cleaning too.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sengweiit97 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,042
